• Home
  • Reviews
  • Advice
  • News
  • Buying Guides
  • Travel
  • For Sale
  • Forums
    • Reviews
    • Advice
    • News
    • Buying Guides
    • Travel
    • For Sale
    • Forums
    • Awards
    Your browser is out-of-date!
    • Reviews
    • Advice
    • News
    • Buying Guides
    • Travel
    • For Sale
    • Forums
    • Awards
    Home › Reviews›Lunar›Delta›TL
    Lunar Delta TL 2009
    £19,795
    Lunar Delta TL
    Lunar Delta TL
    Lunar comes with Al-Ko ATC, side-lift jack and Secure wheel locks
    Conventional front lounge is very practical
    Large kitchen offers excellent storage and plenty of space to prepare meals
    Shower cubicle entrance is big
    Large, flat front bed is very simple to assemble
    Fine kids’ bed area but the bunk guards are not substantial
    Lunar Delta TL
    By Claudia Dowell
    Published: July 28, 2010
    Twin test, June 2009
    A remarkable piece of packaging but lacking a little glamour – 8/10
    Bearing in mind its size, the weight of the Delta TL is simply stunning
    Despite this, it feels plush and upmarket inside
    In addition it offers excellent storage options, generous levels of equipment as standard and boasts a very high build quality.
    The only place where the Lunar’s upmarket feel is missing is in the washroom
    The lack of usable storage for toiletries counts against it, as does the flimsy shower door
    Also, the front corner steadies are too short unless you are on level ground.
    The Lunar is built on an Al-Ko chassis, which includes a hitch-head stabiliser and buttonless handbrake. In addition, the Delta comes with Al-Ko Secure wheel locks for two wheels and the ATC stability control system. The spare wheel is stored in the front locker, rather than in a chassis-mounted carrier. Drains and corner steadies are easily reached but the front steadies are very short meaning that blocks will be needed on even slightly sloping pitches in order to reach the ground.
    Full height front and rear panels and privacy windows mean it looks good if a little understated. The main electrical and heating controls are mounted on the side of the wardrobe, which is not ideal as they are a long way from the main door. The alarm control panel is just inside the entry door.
    The front and rear lounges in the Delta are broadly similar. Both, for example, have centre chests fitted with two drawers and pull-out table extension above. Dining tables for both share a dedicated locker just under the end of the kitchen work surface. Neither table is large enough for six people to eat at without the addition of the centre chest extensions.
    Both lounges benefit from large rooflights and four halogen spotlamps. However, the spots’ fittings are large and feel as though they come from a cheaper model. The only TV stand at either end of the van is on the centre chest.
    The Delta’s kitchen area is pretty spacious with loads of high-gloss work surface and ample storage options. The Dometic Series 8 fridge is large and you can make it even more spacious by removing the freezer compartment. The eye-level microwave is set between two roof lockers in the centre of the kitchen.
    The cooker includes a separate oven and grill, three gas burners and an electric hotplate. Three halogen lamps and a roof-mounted fluorescent make sure the kitchen is well lit. The one drawback may be the cocktail cabinet, which will not be to everyone’s taste.
    This is the only area of the Delta where it feels a bit flat. Aside from the porcelain-bowl version of the Thetford C-250 toilet, little else makes this area special.
    The separate shower cubicle is a usable space, but the bi-fold door feels flimsy and there are only limited storage options. Getting to the under-sink cupboard with the washroom door closed is difficult.
    The large front lounge converts into a bed that is both massive and, with the cushions arranged correctly, flat. To prevent condensation, there are spacer boards around the outside edge. Unfortunately, the kitchen worktop is the only place to rest things at night.
    The bunk beds at the rear are cumbersome to arrange and the bunk guards are wobbly, so care needs to be taken when installing them. You’ll also need to be careful not to knock the halogen spotlights because they sit quite low. The top bunk mattresses are just 50mm thick, but the bottom bunks offer good support. The seats’ backrest cushions need to be stowed at night unless you opt to convert the rear dinette into a double bed.
    With long seat lockers on both sides of both the front and rear lounges, there is plenty of storage space. The one shortcoming is that the water tank encroaches on the available space in the rear, offside box.
    Furthermore, its location back here will force you to empty it before hitting the road to avoid reducing towing stability. There are plenty of roof lockers and the wardrobe is wide and deep.
    Berth6
    MiRO1500 kg
    Payload290 kg
    MTPLM1790 kg
    Shipping Length7.93 m
    Width2.28 m
    Related Reviews
    The Coachman Laser Xtra 845
    Caravans
    Coachman Laser 845 Xtra 2026
    4-berth
    1916 kg MTPLM
    £43,900
    Coachman does not disappoint with the Laser 845 Xtra, which mixes quality with practicality, says Andrew...
    The Swift Challenger 390
    Caravans
    Swift Challenger 390 2026
    2-berth
    1118 kg MTPLM
    £25,195
    The Swift Challenger 390 is an end-kitchen two-berth which is small in size, but packs a...
    The Adria Adora 612 DL Seine
    Caravans
    Adria Adora 612 DL Seine 2025
    5-berth
    1800 kg MTPLM
    £34,030
    The Adria Adora 612 DL Seine is an innovative and versatile caravan from the brand's mid-market...
    The mounted charger
    Accessories
    Ecoflow Alternator Charger & Delta Max 2000 Powerbank
    £1,378.00
    This battery charger and powerbank combo can run all of your gadgets off-grid, says Peter Rosenthal
    Coachman Laser 575 Xtra
    Caravans
    Coachman Laser 575 Xtra 2023
    4-berth
    1734 kg MTPLM
    £39,180
    Nigel Hutson finds the extra width makes all the difference inside a Coachman Laser 575 Xtra
    Adria Alpina Rio Grande
    Caravans
    Adria Alpina Rio Grande 2023
    4-berth
    2000 kg MTPLM
    £43,646
    The front kitchen might not be to everybody’s taste, but the Adria Alpina Rio Grande is...
    The Superb has been updated, adding extra safety and convenience systems and tweaking the styling
    Tow Cars
    Škoda Superb Estate 2022
    2000 kg Max. Tow
    266 lbf-ft Torque
    £33,760
    The Škoda lives up to its name, offering excellent fuel economy and reliable towing performance
    C-shaped lounge seating is opulently upholstered for maximum comfort
    Caravans
    Adria Adora Tiber 2022
    4-berth
    1800 kg MTPLM
    £25,995
    The new 8ft-wide four-berth from the Slovenian brand offers generous space and smart styling
    • About Us
    • Contact Us
    • Cookies Policy
    • Privacy Policy
    • Terms & Conditions
    • Accessibility Statement
    • Categories
    • Tags
    • Authors
    • Privacy Settings
