These new, heavy-duty levelling ramps are 170mm (6.5in) high, to lift your van more than any other ramp can. It does so in four stages, in the shape of a pocket, where the tyres can rest securely. The flat base prevents it from sinking into soft ground and the business side is composed of box-like sections for extra strength without added weight.
Each box has holes to allow water to drain and instructions have been embossed on the base. Each pair comes with a carry case, and single levels are available from around £20. Milenco Quattro Levels are available from accessory shops.
