Grass pitches are fine if the weather is dry and the ground isn’t soggy. However, if it hasn’t been so kind you may find yourself literally stuck in the mud. If your car hasn’t got the power of four-wheel drive it might prove a struggle to get out.
This is where Mud Paddles come in. This product is a set of stainless steel paddles that attach to the car's drive wheels to help you get over soft ground. The paddles are easy to fit and suit most common wheel sizes. As they avoid wheel spinning you won’t damage the grass, which will keep the warden happy.
This is where Mud Paddles come in. This product is a set of stainless steel paddles that attach to the car’s drive wheels to help you get over soft ground. The paddles are easy to fit and suit most common wheel sizes. As they avoid wheel spinning you won’t damage the grass, which will keep the warden happy.
