Before you get behind the wheel, make sure you have the right driving accessories to hand – they won’t take up much space but are sure to make the journey a smoother experience…
Aguri Sat-Nav RV520
One of the shortlisted options for best caravan sat nav at the Practical Caravan Awards 2022 this model from Aguri is currently available for £219.99. Coming with free wireless map and speed trap updates for life, the device will take into account your vehicle’s size so you can avoid any low bridges, road restrictions and more.
Nextbase 320XR+ Front and Rear Dash Cam Bundle with 32GB SD Card
This brilliant device will give you some peace of mind on the road. Easy to install, the device is able to capture details in clear 1080p full HD, with both the front and rear cameras having a 140 degree viewing angle. The bundle includes a 32GB SD Card that can record up two hours of footage as well.
Tyrepal TC215B Monitor System
Keep an eye on your tyre pressure with the Tyrepal TC215B Monitor System, which allows you to see each tyre’s temperature.
From £19.99 at primaleisure.com
Philip’s Camping and Caravanning Atlas of Britain
It’s not all tech in this section. While a sat-nav is all well and good, but sometimes, you can’t beat a good old road atlas. This one from Phillip’s highlights more than 1,880 campsites and 8,600 restricted bridges to help you reach your destination safely.
The AA Ultimate First Aid Kit
It’s always worth having a first aid kit in your car, just in case anything unexpected occurs while you’re on the road. This kit from the AA includes plenty of essentials, such as an emergency blanket, bandages and dressings to help deal with any unforeseen incidents.
Chilly’s Water Bottle
This reusable water bottle from Chilly’s is leak proof so you will not need to worry about any liquid spilling inside your tow car. It can keep your drink hot for up to 12 hours and cold for up to 24 hours.
Torchy 2K Pocket Torch
Are you going to be arriving at the campsite later in the day when it’s beginning to get a bit dark? Make sure you have a torch to hand so you can see where you’re going straight away. This useful product has five different light modes and is also water-resistant.
After some more brilliant accessories inspiration? Our Back to Basics: Accessories category has some unmissable round-ups, full of tour enhancing ideas.
