Starting out in summer 1969 and named for the moon landings, Lunar began with just two models. By the mid-1970s, it had moved to larger premises and launched the Clubman.
These lightweight luxury caravans rapidly became one of the most popular caravan ranges seen on the road.
The company, founded by Brian Talbot and Ken Wilcock, aimed to produce high-quality, lightweight caravans that were both functional and stylish.
Over the years, Lunar would see several different owners, but by 2019, the company was struggling, and it finally ceased trading after some 50 years. However, the brand continues to have a loyal fanbase, as seen by the gold medal achieved in the pre-owned manufacturer category at the recent Owner Satisfaction Awards 2025, where the leading makes of caravans are revealed.
Clubmans remained popular, but were not without problems, and models built in the firm’s last couple of years were prone to issues with damp. So would this example from 2019 make a good pre-owned choice?
The Clubman range stretches back to 1975, with numerous models and caravan layouts produced over that time. The Clubman SR was launched for 2017, so its production run was a bit limited, but if you look around, you can still find them.
The SR’s layout provided a central washroom, a bedroom to the rear, a front lounge and a side kitchen. The spec included an alarm, a BBQ point, an external side locker, an exterior mains socket, alloy wheels, Alde heating, a full oven and a fridge/freezer.
The high-quality upholstery proved pretty popular, too.
For 2019, the Clubman range had updated soft furnishings and stain-resistant carpets. The new finish to the locker doors, in an elegant magnolia, gave the interior a real touch of class, and the new spotlights included those all-important USB charging points, something which could be a feature you look for when choosing the best used caravan.
On the outside, new graphics enhanced the van’s good looks. Other improvements included the addition of the latest Lunar Assist control panel.
The SR was generally well planned, although some buyers found the bedroom a bit small. The 2019 models were the last to be built, but the Clubman remains a popular used choice.
How much to pay for a Lunar Clubman
We found some good examples of the Clubman, with prices staying firm at around the £15,995 to £16,995 mark, depending on condition.
- CK £14,495-£14,995
- ES £15,495-£15,995
- SB £16,995-£17,995
- SI £16,995-£17,995
- SE £15,995-£16,695
Alternative models
Looking elsewhere, you could keep an eye out for a 2018 Swift Conqueror 560, a single-axle with end bedroom and central washroom, for around £19,999.
The Swift looks very smart and comes with an equally good spec, but do bear in mind that it is heavier than the Lunar.
Otherwise, check out Coachman’s VIP 545 from 2020, offering the same layout and excellent build quality, all for around £22,950.
Things to look for in a Lunar Clubman SR 2019
When you’re buying a used caravan, there are numerous checks to carry out – in the case of the Lunar, things to look for include:
- Dents in side panels
- Snug fit in front gas locker
- Cracking in rear panels
- Sponginess in floors
- Signs of damp in rear panel, overhead lockers, washroom and ceiling
- Leaky edges on rooflight
Verdict on the Lunar Clubman SR 2019
It’s impressive how well prices have held for Lunar caravans. The Clubman retains its loyal fanbase, even six years after production ended.
Carry out all of the usual checks and you could bag yourself a bargain. Just don’t leave anything to chance, as some of these vans did have problems with damp. So check for a caravan servicing history and if any repairs have been done, make sure they have been done well.
The Lunar Clubman was a good range and this SR was a particularly fine example.
When you’re choosing the tourer for you, it could be worth finding out about the various types of caravans, to ensure you find the model that best suits your requirements.
Technical spec of a 2019 Lunar Clubman SR
- Berths: 4
- MiRO: 1340kg
- Payload: 155kg
- MTPLM: 1495kg
- Internal length: 5.77m
- Width: 2.34m
