• Home
  • Reviews
  • Advice
  • News
  • Buying Guides
  • Travel
  • For Sale
  • Forums
    • Reviews
    • Advice
    • News
    • Buying Guides
    • Travel
    • For Sale
    • Forums
    • Awards
    Your browser is out-of-date!
    • Reviews
    • Advice
    • News
    • Buying Guides
    • Travel
    • For Sale
    • Forums
    • Awards
    Home › Reviews›Elddis›Xplore›544
    Elddis Xplore 544 2010
    £12,249
    Lack of stabiliser can be addressed by adding it to the options list
    Bright and breezy upholstery stops Xplore range from feeling drab or downmarket
    Recessed drainer robs work space but flip-up extension is useful
    Towel ring is oddly located at head height away from the shower
    Cupboard beneath wardrobe is a useful place to keep shoes
    By Claudia Dowell
    Published: July 30, 2010
    First look, June 2010 When the Xplore line up appeared in early 2008, it was well equipped, but lacked sparkle. The 2010 revamp addressed that, ditching the insipid beige interior and green exterior graphics in favour of something more fun. The range is one of Practical Caravan’s favourites. The Xplore 544 sports a nearside fixed bed layout with a corner washroom. A big seller in the past, this layout has been largely superseded by the rear washroom models which appeared in 2009. There is still plenty to commend the corner washroom model however. The layout feels very open and is a very comfortable caravan for a couple, particularly if they favour using onsite washroom facilities.
    Cheerful, spacious single-axle fixed bed that can be towed by a regular family car.
    The Xplore 544 works really well
    It has a large front lounge, a sensible weight and is good value
    The small washroom may put some buyers off and there is no stabiliser
    As with all Elddis products, the Xplore uses a BPW chassis but it is a lesser version than used on the other Elddis models. As a result, there is no standard stabiliser but it does help keep the weight sensible. The rear exiting waste pipes are fine unless you are on a pitch sloping from front to back.
    Inside the van, the lounge seating is supremely comfortable, with firm, supportive cushions that are better than you’d expect to find in an entry-level tourer. The upholstery is bright and breezy and shows that cheaper tourers don’t need to be deathly dull inside. The only noticeable cost cutting is the single spotlamp on either side of the lounge and a carpet runner rather than a fitted piece of carpet. The van is prewired to make installing a CD/Radio easy, but there is not one fitted as standard.
    The kitchen takes up lots of space in this long single axle caravan. The three burner gas hob, separate oven and grill and a large fridge mean it lacks no essential kitchen kit. Storage is good too but the recessed sink drainer robs the van of workspace. The sideboard on the nearside provides plenty of space to rest plates while serving up though and the fold-out extension flap is a perfect perch for an electric kettle. The biggest gripe is that £12000 caravans should not need matches to light the oven.
    The washroom is the weakest point, but it’s only partly down to the small size. Having the basin at 45 degrees to the wall makes that area of the van feel cramped although getting into the cupboard under the sink is easy. The washroom works well otherwise.
    Storage is a little lacking and the towel hook is outside the shower above the washhand basin. Just make sure you the coast is clear before going and getting your towel. The submersible water pump was more than capable of providing a shower but the van must be absolutely level to ensure the tray drains properly.
    The bed mattress is thinner than found in posher tourers. It is fine for a week on site, but for longer tours, you might be better upgrading to an Avante model which boasts a thicker mattress. There are a pair of spotlights above the bed but no suitable little shelves for night time paraphernalia. The front bed makes up in the normal way with pull-out slats and offers better support than the rear bed and is pretty flat too.
    Storage for two people is very generous and with loads of roof lockers all around and the sideboard unit at the foot of the bed can swallow all manner of touring kit without flinching. Storage underneath the bed is generous, the wardrobe is large and has a useful cupboard underneath for shoes. We found that the locker doors don’t quite lift high enough for comfort and more shelves would be useful.
    Berth4
    MiRO1151 kg
    Payload199 kg
    MTPLM1350 kg
    Shipping Length7.34 m
    Width2.15 m
    Related Reviews
    The Elddis Avante Apex 550 on a forecourt
    Caravans
    Elddis Avante Apex 550 2026
    4-berth
    1481 kg MTPLM
    £31,700
    A welcome refresh has given the Elddis Avante Apex 550 renewed appeal to younger couples, says...
    The Elddis Whirlwind 554
    Caravans
    Elddis Whirlwind 554 2026
    4-berth
    1470 kg MTPLM
    £27,750
    Offering a generous yet affordable spec, the new Elddis Whirlwind 554 is a real breath of...
    The Elddis Whirlwind 868
    Caravans
    Elddis Whirlwind 868 2026
    6-berth
    1745 kg MTPLM
    £29,999
    The Elddis Whirlwind 868 is a back-to-basics caravan that should appeal to families who are shopping...
    The Xplore XC Duo
    Caravans
    Xplore XC Duo 2025
    2-berth
    1150 kg MTPLM
    £23,499
    The Xplore XC Duo is the latest iteration of this smart, comfortable two-berth, and provides welcome...
    The Elddis Crusader Mistral
    Caravans
    Elddis Crusader Mistral 2025
    4-berth
    1660 kg MTPLM
    £35,699
    The Elddis Crusader Mistral is a reliable, family-friendly four-berth that boasts valuable extras in the 60th...
    The Xplore XC Lite
    Caravans
    Xplore XC Lite 2025
    4-berth
    1090 kg MTPLM
    £21,999
    Restyled as the Xplore XC Lite for a younger market, Peter Baber goes to see if...
    The Xplore XC Quad
    Caravans
    Xplore XC Quad 2025
    1380 kg MTPLM
    £25,499
    Good looks combine with a generous spec to make the Xplore XC Quad an appealing entry-level...
    The Swift Sprite Alpine 4 DB
    Caravans
    Swift Sprite Alpine 4 DB 2026
    4-berth
    1263 kg MTPLM
    £21,495
    With Sprite now streamlined and lower in price, the Swift Sprite Alpine 4 DB offers great...
    • About Us
    • Contact Us
    • Cookies Policy
    • Privacy Policy
    • Terms & Conditions
    • Accessibility Statement
    • Categories
    • Tags
    • Authors
    • Privacy Settings
