• Home
  • Reviews
  • Advice
  • News
  • Buying Guides
  • Travel
  • For Sale
  • Forums
    • Reviews
    • Advice
    • News
    • Buying Guides
    • Travel
    • For Sale
    • Forums
    • Awards
    Your browser is out-of-date!
    • Reviews
    • Advice
    • News
    • Buying Guides
    • Travel
    • For Sale
    • Forums
    • Awards
    Home › Reviews›Lunar›Quasar›534
    Lunar Quasar 534 2011
    £14,795
    Find out more about the four-berth Lunar Quasar 534 in the Practical Caravan review
    Get inside this tourer with Practical Caravan – it is priced from £14,795
    Worktop space is lacking in this 534, but there's a good level of kit
    Worktop space is lacking in this 534, but there’s a good level of kit
    The washroom might be on the compact size, but it is user-friendly
    The fixed double bed is a welcome feature in this tourer
    Storage is good and it is easy to access in this caravan
    The lounge will easily sit the four that the van can sleep
    This radio/CD/MP3 player is in the front overhead locker
    Read the Practical Caravan Lunar Quasar 534 review for the full story on this tourer
    This four-berth tourer has a fixed double bed
    Published: January 24, 2011
    Read the Practical Caravan Lunar Quasar 534 review to find out if this fixed bed option could be a winner for your caravan holidays
    The Lunar Quasar 534 is heavier, longer and more expensive than many of its direct rivals, but if those things aren’t an issue for you, it’s well worth taking a close look at what this capable caravan has to offer, because it really makes its interior space work well. That’s particularly true in the lounge, even if that area isn’t the last word in absolute comfort.
    This really is a fixed-bed tourer that doesn’t feel claustrophobic. And, in this class, that’s quite an achievement.
    The overall feel is light and airy
    The layout is cleverly arranged to make the most of the living space
    The storage options are many and easy to use
    Both double beds are large
    Although user-friendly, the washroom is small and leaves little space to dry off after a shower
    In the kitchen, there is meagre work surface, and practically none if your dishes are draining
    The lounge backrests are quite stiff
    A fixed-bed tourer that doesn't feel claustrophobic – in this class, that's quite an achievement
    Lunar’s Quasar 534 comes with an Al-Ko chassis and stabiliser, buttonless handbrake and 13-pin electrics as standard. Getting to the steadies is easy, with metal guide channels at the front and exposed rear winding bolts.
    The controls are on the inside-left of the entrance and waste pipes can be found on the offside-just behind the axle. The front locker is roomy and has a large door held by two gas struts. Also included is a barbecue point, super-pitch water connection, external awning LED light and 230V socket. Its external wet locker is found on the offside rear of the van.
    Lunar has kept the styling simple but modern and its light-coloured wood and fabrics give a bright, airy feel. The locker doors feel solid and feature removable shelving. Although the lounge seats’ backrests are a little stiff, the bases are comfortable and now include aluminium spring-loaded bases for easy access to the storage and switchgear beneath.
    There are two bolster cushions per bench, and 230V and TV aerial sockets. A radio/CD/MP3 player is located in a front overhead locker. Below is the central chest, which has two drawers and a pull-out table extension.
    The Quasar’s kitchen is well equipped, having a 112-litre Thetford fridge, separate oven and grill, three-burner gas hob with electric hotplate and, directly above it all, a microwave. The workspace, which is to the left of the sink, isn’t huge but a removable drainage board helps make it more usable.
    There is a small cupboard below the cooker for keeping pots and pans, a cutlery drawer and a narrow space with a door for stowing the table on the left side of the kitchen. The single overhead locker is small, but is fitted with plate and cup holders and should provide enough space to store place settings for four.
    While the Lunar can’t claim to have the most spacious washroom, the area has been made as user-friendly as possible. The space is bright, thanks to a Heki rooflight, and comprises a good-size shower, which is passed through to access the toilet. The toilet and shower can be separated by a folding glass divider.
    With the toilet turned, there is sufficient legroom and Lunar’s decision to fit a large, overhead shelf at the rear of the washroom was a clever one. There is little room for drying inside. But there is a vanity unit, which includes a basin, large mirror, toothbrush holder and small cupboard to help make getting ready easier.
    The nearside, 1.91m x 1.35m fixed bed is large and comfortable, thanks to a new luxury spring mattress. The area is well lit, with a large Heki rooflight and window letting in daylight and two corner spots for the night.
    The front double, which at 2.01m x 1.53m is also large, is assembled using slats pulled from below the centre chest. The slats are on runners and the lounge cushions are a great fit, making the whole process quick and easy. The two sleeping areas can be separated using the fabric divider.
    There are four overhead lockers in the lounge, one in the kitchen and four more above the fixed bed. Unfortunately the lounge and kitchen lockers are very shallow. However, the rear lockers provide ample room for belongings.
    Storage and switchgear below the front seats is easily and safely accessed thanks to supporting struts, while the area below the fixed bed is large and its struts lift the bed high for easy use.
    At the foot of the bed is a brilliant worktop with two further overhead lockers, one drawer and two small cupboards. As well as this, there is a wardrobe between the kitchen and the vanity.
    Berth4
    MiRO1191 kg
    Payload154 kg
    MTPLM1345 kg
    Shipping Length6.78 m
    Width2.16 m
    Related Reviews
    The 2011 Lunar Quasar 534 offers two big double beds, but there's a catch – read Practical Caravan's expert verdict, full spec, prices and rival caravans
    Caravans
    4-berth
    1345 kg MTPLM
    £14,795
    The 2011 Lunar Quasar 534 offers two big double beds and a generous lounge, but the...
    The Coachman Laser Xtra 845
    Caravans
    Coachman Laser 845 Xtra 2026
    4-berth
    1916 kg MTPLM
    £43,900
    Coachman does not disappoint with the Laser 845 Xtra, which mixes quality with practicality, says Andrew...
    The Swift Challenger 390
    Caravans
    Swift Challenger 390 2026
    2-berth
    1118 kg MTPLM
    £25,195
    The Swift Challenger 390 is an end-kitchen two-berth which is small in size, but packs a...
    Coachman Laser 575 Xtra
    Caravans
    Coachman Laser 575 Xtra 2023
    4-berth
    1734 kg MTPLM
    £39,180
    Nigel Hutson finds the extra width makes all the difference inside a Coachman Laser 575 Xtra
    There’s no mistaking the distinctive exterior of the Airstream Tourer 534
    Caravans
    Airstream Tourer 534 2022
    4-berth
    1900 kg MTPLM
    £85,000
    It’s eye-catchingly stylish and looks very upmarket, but the spec could be more generous for the...
    The Superb has been updated, adding extra safety and convenience systems and tweaking the styling
    Tow Cars
    Škoda Superb Estate 2022
    2000 kg Max. Tow
    266 lbf-ft Torque
    £33,760
    The Škoda lives up to its name, offering excellent fuel economy and reliable towing performance
    Good lighting makes the kids' bedroom feel very spacious
    Caravans
    Swift Leisure Home Prestbury 2021
    6-berth
    1550 kg MTPLM
    £22,395
    In a crowded market, the numerous extras in this family-friendly dealer special make it stand out
    Some might want for a proper nearside window, but the large front gas locker is welcome. Neat graphics and smart alloys look good
    Caravans
    Lunar Quasar 696 T/A 2019
    6-berth
    1680 kg MTPLM
    £23,995
    Lunar caught the eye of visitors to last year's NEC show with its newest eight-foot-wide family...
    • About Us
    • Contact Us
    • Cookies Policy
    • Privacy Policy
    • Terms & Conditions
    • Accessibility Statement
    • Categories
    • Tags
    • Authors
    • Privacy Settings
