I’ve been tempted by an ebike for some time now – I’ve tried a few over the years, and always been impressed by the practicality and fun they offer. So I jumped at the opportunity to test the latest CGR E AL Sportfit Apex XPLR from British brand Ribble. I’ve ridden a couple of its bikes in the past – including the non-electric Ribble Hybrid AL Trail Disc Enthusiast – which gave me a good chance to compare them.
A good bike can make exploring when you’re pitched up at the best caravan parks that much simpler, so it’s a buy you’re going to want to get right.
Ribble has been building bikes since 1897 and, although it does have a number of stores, it’s primarily an online retailer.
This model was delivered to me pretty much ready to go, though – all I needed to do was fit the handlebars and pedals, and I was on the road. (If buying online is a concern, Ribble’s 30-day returns policy offers great peace of mind).
One of the reasons I wanted to try this particular cycle is its light weight – with its 7005-series hydroformed alloy frame, it comes in at just 13.7kg, lighter than many alternatives, which will come in handy when loading a caravan for a tour. That means I can lift it onto a tow car cycle carrier reasonably easily when I’m away in a caravan. I also really like this bike’s smart looks – the battery pack is so well concealed in the frame that you wouldn’t necessarily know that it’s an electric model.
Selecting the power
Simply press the button on the frame to select power
Accessing the bike’s electric assistance is really straightforward. There’s a button on the frame that you hold down for a couple of seconds; this switches the power on. You then press it again to cycle through the various levels of assistance; the amount you have dialled in is represented by a clear colour (green for one-third assistance, orange for two-thirds, and purple for full assistance). The power can also be selected via a thumb-operated rocker switch on the left-hand side of the handlebars.
The SRAM disc brakes
SRAM disc brakes feel very efficient and solid on the road
Out on the road, I found the electric assistance to be excellent – it was simple to select the power level that I needed, no matter what the terrain. The Mahle X30 rear hub motor is silent and provides assistance that feels natural, while the SRAM Apex XPLR gearing operated smoothly whenever I needed it. I tried the bike on a variety of surfaces (including muddy roads) and I appreciated the Schwalbe G-One Allround tyres, which gave good grip and inspired confidence.
The charging slot
The supplied charger plugs neatly into the bike frame
Charging the bike’s 250Wh battery – which is neatly hidden in the down tube of the frame – is simple: just plug the supplied 4A charger into the socket at the base of the frame. The battery is charged to around 80% capacity within two hours or so. You can also use Mahle’s Smartbike phone app to monitor the power.
The range of this bike is claimed to be about 60 miles, depending on your riding, and the bike’s lighter weight does mean that it can still be comfortably used as a regular bike if you do run out of power.
For those of you who are heading off on tour soon, don’t miss our guide to the 16 easy jobs to help you achieve trouble-free touring.
Technical specification
  • Price: £2799 (usually £2899)
  • Weight: 13.7kg
  • Range: Around 60 miles
  • Battery: 250Wh unit, within frame
  • Motor: Mahle X30
  • Gears: 12-speed SRAM Apex XPLR drivetrain
  • Tyres: Schwalbe G-One Allround RaceGuard Folding Tyre Black 700c x 40mm
  • Frame: 7005-series hydroformed alloy
  • Saddle: Selle Italia Model X
  • Colour: Black and Aqua Blue
  • Charging time: Two hours up to 80%
  • Maximum rider weight (inc bike): 120kg
  • Web: ribblecycles.co.uk
