Bailey introduced the Pegasus for the 2010 season, its first range constructed using the Alu-Tech system. Over time, it evolved and by 2016, the Pegasus was on its third generation.
For that year, the line-up consisted of seven caravan layouts, giving lots of choice to the potential buyer.
By that third generation, the Pegasus was offering improved spec and an upgraded interior. The absence of wood in its main construction also meant that leaks should cause no structural damage, but the wooden floors were still vulnerable, however.
To see how the range is doing these days and whether those on the lookout for the best secondhand caravans should consider it, I took a look at a well-presented Bailey Pegasus Modena model from the 2016 line-up.
Model history of the Bailey Pegasus Modena
The 2016 season saw the launch of the Modena, a new model in the range that was lightweight and yet offered a side fixed bed and rear full-width washroom. You also got a front lounge with an offside kitchen, and all this was packed into in an internal length of just under 5m. That made the Modena an attractively compact fixed-bed layout.
It slept up to four occupants, with the front lounge seating being used to make up into a double bed.
This was really a caravan for couples, however, and with its lighter weight, the Modena was also towable by most cars (see: matching a car to a caravan for the steps involved in doing this).
In common with the rest of the Pegasus range that year, the Modena had external locker access to the side, an exterior mains socket, Truma blown-air heating system, a full oven, a microwave and a fridge.
It also came supplied with a radio/CD player, a Status TV aerial and LED spotlights.
There was no front gas bottle locker, as it had been replaced with a gas-only locker sited on the offside wall.
Inside, plenty of overhead locker space was provided, as well as a wardrobe – ideal for the clothes of a couple, and especially those who might be planning longer tours.
However, with the arrival of the fourth-generation Pegasus range in 2018, the line-up was renamed Pegasus GT70 (as part of the celebrations for Bailey’s 70 years in manufacturing), and the Modena was no longer listed.
Price checker
I took a good look around and found one 2017 example priced at £15,795, and another, this time a private sale, at just £12,995. So the model that I review here is at the upper end of the price band – but it was in immaculate condition.
For the rest of the range, you can expect to pay:
- Genoa: £13,995-£14,499
- Verona: £13,750-£15,295
- Brindisi: £14,995-£16,295
- Rimini: £13,995-£14,995
- Ancona: £13,599-£15,695
- Palermo: £15,995-16,995
What to look out for
- Fading on side panels
- Signs of leaking in the roof
- Evidence of damp, mainly in the floors leading to rot
- Water stains on interior walls
- Loss of support in upholstery
- Awning not threading through the channel as it should
Verdict on a 2016 Bailey Pegasus Modena
Pegasus Modena tourers dating from 2015 to 2017 are currently well-priced on the pre-owned market, always a benefit if you’re looking at buying a used caravan.
The thoughtfully designed, comfortable Modena, although technically a four-berth, would make a fine choice for couples.
As always, it’s important to carry out the usual checks on the Modena, in particular for signs of caravan water ingress in the washroom and evidence of any rotting in the floors.
The Bailey Pegasus Modena also offers a good spec and timeless décor, adding to its attractiveness as a great first-time purchase.
Technical spec of the 2016 Bailey Pegasus Modena
- Berths: 4
- MiRO: 1126kg
- Payload: 149kg
- MTPLM: 1275kg
- Internal length: 4.95m
- Width: 2.23m
Alternative models
Take a look at the Swift Sprite Alpine 4, another side fixed bed layout, but with a corner washroom. Watch for dealer specials if you’re after more kit. If you prefer a newer model, try a 2019 Alpine, priced at £16,495 to £16,999 (although unlike the Modena, it doesn’t have a full-width washroom).
For a lighter, newer tourer, you should find a 2020 Bailey Discovery D4 for £14,995 to £15,595, which provides the same layout as the Modena.
