Polishing a caravan is a huge undertaking, as the surface area is three or four times that of a car. However, the benefits of carrying out this maintenance task are that it’s a great way to protect your investment and keep it looking spic and span, which will come in particularly handy if you decide to sell it on too. As a result, knowing how to polish a caravan is going to be an important task for van owners.
Start by cleaning a caravan thoroughly, ensuring you remove any grit and dirt from the surfaces. I recommend using one of the best caravan cleaners – at Practical Caravan, we recommend using either Fenwicks Caravan Cleaner or Autoglym Motorhome & Caravan Cleaner, both of which are easy to use and super-effective.
Failing to clean your tourer first could lead to rubbing contaminants into the bodywork when polishing, which causes micro-scratch swirls in the surface finish.
When your caravan is clean, we’d recommend reaching for the best caravan polish, from the likes of Autoglym, Silky or Care-avan. Ok, you don’t need to pick a specific ‘caravan polish’, as the ingredients are very similar for cars, boats or tourers. However, the better (premium-priced) brands are likely to contain more of the good stuff.
Use a sponge pad or a clean cloth to apply the polish. Most suggest rubbing the polish on in a circular motion, working the solution into the surface. Let the polish dry for a few minutes, then buff it off with a clean microfibre cloth. On hot days, do this in the evening when the surface temperature of the caravan is going to be lower.
Polishing will help to make your caravan walls and roof hydrophobic, so rain water will bead and roll off the surface. It will create a microscopically-thin protective shell too, protecting from the damaging effects of bird poo and tree sap, and making both easier to remove.
You could go one step further, by protecting your van with a ceramic coating from the likes of Diamondbrite or Paintseal. These are typically applied by a technician and create a tough-but-invisible layer of protection that lasts for several years, resists dirt and makes cleaning much easier.
Finally, if the fibreglass finish on your old tourer has started to dry out and go powdery, a good dose of a quality polish will hide the worst of the deterioration and recreate a shiny finish.
While you’re sprucing up your tourer, one area you will not want to overlook is the roof – it can be the dirtiest part of your tourer. If you’re unsure about the steps involved, don’t miss my guide to how to clean a caravan roof to ensure you get it looking its best.
