Amazon’s spring sale is underway, providing caravanners with the chance to stock up on those useful gadgets and accessories that could improve any touring experience.
This year, the Spring Deal Days event is running from Tuesday 10th to Monday 16th March, giving plenty of time to find some must-have items in time for the new season and nicer weather.
There’s no denying these sales can sometimes feel daunting to browse, especially as it can be hard to tell if the offers are any good or not. Fear not. I’ll be your guide, sharing my favourite deals I’ve seen so far.
I’ll also be using price checking tools, including CamelCamelCamel and Keepa, which allow me to track the prices seen throughout the year, so you know the savings you’re getting are actually worth it – or at least flag that it’s not quite as good a saving as previously.
To make my pick of the deals easier, you can also quickly navigate to a section via the jump links below.
Entertainment gadgets for caravans
On tour power
Caravan security
Caravan cleaning products
Cooking on tour
soundcore Anker 2 Portable Bluetooth Speaker with 12W Stereo Sound was £39.99 now £24.98 (save 38%)
For those who want to improve their music setup on tour with a relatively budget-friendly speaker, this Anker option could be a tempting deal. Its IPX7 protection should make it fairly sturdy and able to stand up to rain, while it has a 5,200mAh Li-ion battery which lasts for up to 24 hours. It should also be able to provide good sound quality, thanks to its BassUp technology, helping you enjoy your favourite music on the go.
Amazon Fire TV Stick was £39.99 now £23.99 (save 40%)
If you have a touring TV that works perfectly well but doesn’t allow you to access streaming services, an Amazon Fire Stick can be a great solution and save you from having to buy a new set. Simply requiring a HDMI port, the stick can be plugged in and, so long as you have access to the internet, will allow you to enjoy Netflix, Apple TV+, Disney+, Prime Video and watch live TV through ITVX in full HD. A 40% saving brings it down to only £23.99 over Spring Deal Days.
NEBULA Capsule 3 Mini was £499.99 now £299 (save 40%)
I’ve been testing this projector recently, and I’m very impressed (in fact, I’m not sure I’d ever consider buying a TV for a caravan, after trying this projector). Picture quality is good, and it can project at up to 120 inches, allowing you to truly re-create a cinema experience on tour. Sound quality has also been good, while Nebula says the battery will last for up to 2.5 hours per full charge. It has a 1080p display and 200 ANSI Lumens of brightness, effectively scaling to a size appropriate to the surface it is projected on. Ok, I have noted an occasional bit of lag between pressing buttons on the remote and seeing it occur on screen, but this is generally just after turning it on. The 40% saving brings it down to only £299 and matches the lowest price it has been.
On tour power
Jackery Explorer 1000 v2 was £549 now £379.05 (save 31%)
Matching the price it was available for over Black Friday (which, apart from when it’s been a whole £0.05p cheaper, is the lowest price it’s ever been), the Explorer 1000 v2 best comes with a good selection of six charging ports: two USB-C ports, two Pure Sine Wave AC Ports, and a USB-A port. Features include an output of 1500W and a surge peak of 3000W, and it has a sturdy handle to make transporting it easier. Weighing 11kg, it has a 1070Wh capacity and is CE-certified.
Renogy 1000W Pure Sine Wave Inverter was £159.99 now £109.99
A pure sine wave inverter can help you use more delicate electrical products or gadgets, making them a valuable touring accessory if you’re touring without electric hook-up. Renogy has a range of Pure Sine Wave Inverters in the Amazon spring sale, with 1000W, 2000W and 3000W options all available. It’s the 1000W one we’re looking at here, which is CE-certified and has a 2000W peak during load start-up. It’s available with a 31% saving, which brings it down to £109.99.
EcoFlow DELTA 2 was £549 now £399. (Save 27%)
Providing users with a huge 13 outputs, the Delta 2 offers users an impressive way of staying connected on tour. It has a 1024Wh capacity, but if extra power is required, additional batteries can be purchased to achieve a mighty 3KWh output. It has an output of 1800W and can be controlled via the EcoFlow app. It does weigh 12kg, but comes with a handle to make moving it around easier. Currently reduced by 27%, it is currently matching the lowest price it has ever been on Amazon. Ports include four USB-A ports, two USB-C ports, four AC outlets and three 12V DC outlets.
Renogy 200W Flexible Solar Panel was £179.99 now £152.99 (save 15%)
Capable of providing up to 1000Watt-hours of electricity a day, this Renogy solar panel could be a valuable extra source of power when you’re on tour. It only weighs 4.9kg and can be bent within 240 degrees, allowing you to get the ideal placement. It should be relatively durable too, with the manufacturer saying it’s able to withstand up to 2400 Pa of high wind load, and it also comes with pre-drilled holes to make it simple to install. While it’s currently available with a 15% saving, it was cheaper in December, when it retailed for £136.78, but for those who are looking for extra power on tour in 2026, it still looks a good buy, in my opinion.
Caravan security accessories
Stronghold Atlas Caravan & Trailer Wheel Clamp was £149.99 now £122.63 (save 18%)
At only 5.01kg, this relatively lightweight wheel clamp comes with a Gold Sold Secure rating, and is suitable for use on both steel and alloy wheels that are up to 265mm. It works by using a pair of arms that lock together and then get fixed in place using bolts. Its bright colour will also make it a great visual deterrent. It has been cheaper in the past year – over Black Friday, it dropped to £117.14, and in July, it was available for only £111.57. However, for some peace of mind in time for the new season, we think this makes a tempting option.
Dirtbusters Caravan Cleaner Car Wash & Wax was £19.99 now £16.99 (save 15%)
For those who want to get their tourer looking its best for the new season, this Dirtbusters cleaner could be worth considering. It’s one of our picks for the best caravan cleaner, with the five-litre product able to make up to 1,000 litres of solution. It comes with Carnauba Wax, which forms a water-beading treatment to give the tourer’s paintwork a barrier to provide extra protection. According to CamelCamelCamel, it’s currently the cheapest it’s ever been, too.
Autoglym Fast Glass was £11.49 now £7.43 (save 35%)
There are plenty of savings to be had across the Autoglym range at this Spring Deal Days event, but it’s Fast Glass we’re focusing on here. For those of you who think your caravan’s windows could do with some attention, Fast Glass could be the answer, providing an efficient solution to getting rid of grime, dirt and other external deposits, with the end result being sparkling windows. It’s currently the cheapest it’s been in a year, too.
Autoglym Super Resin Polish was £23.26 now £14.46 (save 38%)
One litre of Autoglym Super Resin Polish should keep you going a while and help you achieve a sparkling tourer in the process. It can be used when you’re polishing a caravan to get rid of any scuffs, light scratches and similar marks. The one-litre bottle is almost as cheap as the smaller 500ml size, which is reduced to £13.49 at the moment.
Cooking on tour
Tower T17021 was £69.99 now £37.16 (save 47%)
An air fryer has become one of the most common kitchen gadgets in our homes in recent years, and if you’re looking to add one to your leisure vehicle’s cooking setup, this Tower is well worth a look. It’s manual, not digital, but it has a good capacity of 4.3 litres and is recommended by Practical Caravan’s editor, Sarah, who has one. Coming in at 4.5kg, it has a 60-minute timer and is 1500 watts.
Beko Solo Microwave MOC20100W1 was £69.99 now £56.52
Providing a 20-litre capacity and coming with a sturdy door handle, this Beko comes in at 10.8kg and is 700W, providing users with six different power settings for some versatile cooking options. It looks smart, too.
