• Home
  • Reviews
  • Advice
  • News
  • Buying Guides
  • Travel
  • For Sale
  • Forums
    • Reviews
    • Advice
    • News
    • Buying Guides
    • Travel
    • For Sale
    • Forums
    • Awards
    Your browser is out-of-date!
    • Reviews
    • Advice
    • News
    • Buying Guides
    • Travel
    • For Sale
    • Forums
    • Awards
    Home › Reviews›Elddis›Avanté›526
    Elddis Avanté 526 2010
    £14,599
    Front locker lid lifts on two gas struts for easier access to the space
    Bold, patterned upholstery gives the area a bright, modern appearance
    Chinchilla lids to hob and sink and  drop-down flap increase work space
    Washroom is too compact for comfort
    The rear fixed bed has a padded headboard, comfy mattress and reading lights
    Pull-out wire shelves make the most of narrow cupboard space
    Published: March 2, 2010
    Twin test, May 2010
    Attractive, well-equipped and desirable but storage and washroom are limited. Works better as a two or four berth.
    The lounge has great curved corner bolsters that you can sit right into and get comfortable
    The shower has good floor space and a bi-fold screen
    Standard equipment includes a microwave and radio/CD player.
    Lack of storage in the washroom will be a struggle with six people’s toiletries to accommodate
    The corner shelves over the fixed bed are so small they couldn’t hold a book or a cuppa.
    The Avanté is built on a BPW chassis and includes a Winterhoff stabiliser, 13-pin electrics and buttonless handbrake.
    The front locker lifts on two gas struts and is roomy enough for two gas bottles. The steadies are easy enough to access and the rear has guide channels. Waste pipes are positioned at the back rather than at the side of the van. Equipment outside includes an awning light, alloy wheels and split entrance door with flyscreen. The mains control and two coat hooks can be found just inside the door.
    The lounge is a mix of traditional and modern. The light wood lockers are traditional in style while the upholstery is a bright modern pattern.
    Curved corner bolster cushions allow full use of the sofa, and deep knee rolls provide added comfort.
    Lighting options include a large roof light plus two corner and two spotlights.
    A radio/CD and two speakers are fitted as standard, and also a TV point and directional aerial. There’s a small flip-up table for occasional use, and for meal times there is an extendable dining table and side dinette.
    The kitchen in the Avanté has a 115litre fridge, three-burner hob, separate oven and grill, recessed sink with drainer and a microwave is fitted as standard. Most of the worktop is to the right of the fridge, which includes a large drop-down hatch. This area has two mains points, but their position means items cannot be permanently plugged in.
    Both the sink and hob have Chinchilla glass tops that can be used as additional workspace. Lighting for the kitchen comes courtesy of a rooflight, mains ceiling and stripped lighting.
    A lightweight door leads into the Avanté washroom. Inside, there is a separate shower with mixer tap and a bi-fold door. The floor space is good plus there is useful hanging rail and rooflight overhead. Behind the shower is a Thetford bench toilet with electric flush. Above this is a drop down sink and mirrored cabinet with a spotlight. Toiletries can be stored in the cabinet or on the frosted shelf below. There is also a cup holder and towel hooks.
    Pull-out slats convert the front lounge into a decent sized double bed. The cushions are simple to arrange and are a good fit. There are two spotlights either side of the far end so both people would have to sleep length ways to benefit from a reading light.
    The side dinette is simple to switch into bunks. Pull-out slats convert the lower bed and the top sits on brackets. The lower bunk has the benefit of deeper sprung cushions but no spotlights. Boards to secure the top bunk are fitted into the base and simply flip up when needed. The top has two spotlights and a wrap-around curtain seals of the area at bedtime. A wooden ladder is provided to access the top bunk, but this is very light and struggles to touch the floor.
    The rear fixed bed measures 1.83mx1.37m and has a headboard and comfy sprung mattress. There is a rooflight overhead and two spotlights for night reading. There are two corner shelves but their size makes them redundant for even cups. For privacy the area shuts off with a sliding fabric door.
    The washroom storage may prove a struggle, as there is only the small cabinet for toiletries or a single shelf.
    Otherwise the vans remaining storage is generally good.
    The rear bed area has four lockers and open corner shelves. There is also plenty of space under the fixed bed for bulky items and an external locker for outside access. Opposite the bed is a large wardrobe with full hanging, but no shelves for folded items.
    The kitchen has one large overhead locker with fitted plate racks and there are open shelves either side of this. Between the fridge and oven is a slim cupboard with a cutlery drawer and two wire racks. Above the drop-down hatch is a TV unit that has space to double up as extra kitchen storage.
    Over the offside dinette there are three overhead lockers and storage under both seats. Both seats have front flaps for easy access.
    In the lounge there are two large lockers and two small shallow lockers. One of the lockers loses space because of the fitted radio and there are no corner shelves.
    Access to the under seat storage is made easy thanks to drop down panels, and there is a decent amount of space in each.
    Berth6
    MiRO1332 kg
    Payload213 kg
    MTPLM1545 kg
    Shipping Length7.34 m
    Width2.23 m
    Related Reviews
    The Elddis Whirlwind 554
    Caravans
    Elddis Whirlwind 554 2026
    4-berth
    1470 kg MTPLM
    £27,750
    Offering a generous yet affordable spec, the new Elddis Whirlwind 554 is a real breath of...
    The Elddis Whirlwind 868
    Caravans
    Elddis Whirlwind 868 2026
    6-berth
    1745 kg MTPLM
    £29,999
    The Elddis Whirlwind 868 is a back-to-basics caravan that should appeal to families who are shopping...
    The Elddis Avanté 520
    Caravans
    Elddis Avanté 520 2025
    2-berth
    1340 kg MTPLM
    £26,299
    A sleek new profile graces the exterior of the Elddis Avanté 520, a compact two-berth which...
    The Elddis Crusader Mistral
    Caravans
    Elddis Crusader Mistral 2025
    4-berth
    1660 kg MTPLM
    £35,699
    The Elddis Crusader Mistral is a reliable, family-friendly four-berth that boasts valuable extras in the 60th...
    Elddis Avanté 550
    Caravans
    Elddis Avanté 550 2024
    4-berth
    1412 kg MTPLM
    £26,599
    Comfortable and capacious, the Elddis Avanté 550 is an entry-level four-berth that is family-friendly and offers...
    The Swift Sprite Alpine 4 DB
    Caravans
    Swift Sprite Alpine 4 DB 2026
    4-berth
    1263 kg MTPLM
    £21,495
    With Sprite now streamlined and lower in price, the Swift Sprite Alpine 4 DB offers great...
    The Xplore XC Duo
    Caravans
    Xplore XC Duo 2025
    2-berth
    1150 kg MTPLM
    £23,499
    The Xplore XC Duo is the latest iteration of this smart, comfortable two-berth, and provides welcome...
    The Kia EV6 GT-Line AWD
    Tow Cars
    Kia EV6 GT-Line AWD 2025
    1800 kg Max. Tow
    446 lbf-ft Torque
    £52,085
    The Kia EV6 GT-Line AWD is a superb tow car which has been further enhanced with...
    • About Us
    • Contact Us
    • Cookies Policy
    • Privacy Policy
    • Terms & Conditions
    • Accessibility Statement
    • Categories
    • Tags
    • Authors
    • Privacy Settings
