Step inside the Motorhome and Caravan Show and you know you will get to see a vast selection of leisure vehicles, with a wide range of exhibitors showcasing the latest new season releases. But the NEC Show is not just the place to go if you’re on the hunt for one of the best caravans; it’s also a great opportunity to stay up to date with the latest developments in caravan tech, too.
Visitors to the show got to see well-known brands exhibiting the latest essential caravan accessories and luxury tour-enhancing products, with Isabella, Avtex and Vango just a few of the names that were showcasing the very latest touring technology.
The must-have accessories can make a real difference to your experience when you’re pitched up. If you were unable to make the Show or didn’t get a chance to check out the technology on display, fear not; we’re sharing the 10 instances of new caravan technology that caught our eye.
EcoFlow DELTA PRO 3
For serious off-grid adventures, you can rely on this powerhouse all-in-one battery/inverter. Whether you’re bound for the Scottish Islands or Morocco, it’ll ensure that you’ll be able to power a caravan off-grid for all your modern-day conveniences.
It’ll run your induction hob, fire up the caravan microwave, charge phones and laptops, help you stay connected via Starlink or cellular, or even power an EcoFlow Wave 3 heater/air-conditioner.
You can recharge it via mains power, EV charging stations, an EcoFlow Alternator Charger, or with caravan solar panels: everything you need to know (fixed or portable).
Avtex 12v TV with Freely
Those looking for the best caravan TV could be interested to hear about Avtex’s new 12V SmartPRO TV range, which is currently the only one with built-in Freely.
Designed for life on the road, Freely gives you instant, free access to live and on-demand TV from BBC, ITV, Channel 4 and Channel 5, via Wi-Fi – no aerial or dish required.
Of course, you can also log into your home streaming services, like Netflix and Amazon. When you’re caravanning off-grid or out of signal, you can still use its integrated DVB-T2 and DVB-S2 tuners for traditional terrestrial or satellite viewing.
The SmartPRO runs on 12V or 240V power, with an intelligent power supply and an on-screen battery monitor to protect your leisure battery. There’s also one-button auto-tuning, USB recording, Bluetooth, and app or voice control.
Slim, light and frameless, it mounts neatly and stylishly in even the most compact van. In short, this TV brings effortless, high-quality entertainment wherever your adventure takes you.
Falcon Technology 5G Portable Router (eSIM compatible)
The new-for-2026 5G portable router from Falcon, is built with those in mind who want to have good access to caravan internet. This super-fast unlocked unit supports both nano-SIM and eSIM profiles, meaning you’re free to pick the best data plan without being tied in.
It boasts dual-band support (2.4 GHz & 5 GHz) and Wi-Fi 6 capabilities, connects up to 32 devices at once and delivers blazing speeds with downloads of up to 3.4 Gbps when 5G is available. A 4500mAh quick-charge battery lets it function as a hotspot, on the campsite, in the hills or at the beach; and security is future-proofed with WPA3 encryption.
For the touring lifestyle, this means you can stream, work or keep the kids entertained in the van or on the move, without relying solely on slow or often expensive campsite caravan Wi-Fi.
Price: £499 at Falcon
Vango Dynamic Weave Fabric
Vango’s innovative, new Dynamic Weave 100 fabric is a clever material, designed to combine strength and light weight perfectly. These qualities make it ideal for awnings and tents for ‘weekend warriors’, and those taking extended caravan or motorhome breaks.
Dynamic Weave uses a cross-hatch of 70D and 100D fibres, which gives it a brilliant strength-to-weight ratio, meaning it’s strong enough to handle rough weather yet light enough to pack and transport easily.
Compared with standard tent fabrics, Dynamic Weave is up to 23% stronger and 13% more tear-resistant, so it’ll shrug off those gusty nights and the odd guy-rope trip! It’s also impressively UV-resistant – four times better than the BSI minimum – and offers waterproof protection up to 4000mm.
The result is a fabric that lasts longer, looks better and performs beautifully in all conditions.
Price: £270 for the Vango Palma 260 awning
Isabella Compressor Coolbox
Heading off for a weekend escape, road trip or camping adventure? This tough, 40-litre compressor cool box is your ideal travel mate. It chills food and drinks quickly and quietly (≤38 dB), keeping everything refreshingly cool wherever you go.
The adjustable temperature range from -20 °C to +20 °C means you can freeze or refrigerate as needed, while Eco and Max modes balance efficiency and speed. Power it via 12/24V in your car or 230V at home – both cables are supplied. With three levels of battery protection, your vehicle’s power stays safe, while an automatic child lock prevents accidental adjustments. A handy divider creates two compartments, and you can manage everything via the clear display or the Tuya Smart Life smartphone app.
Price: £320 at isabella.net
Roamer Lithium Leisure Batteries
The best caravan leisure battery is a real touring essential, and if you’re looking for one, Roamer’s new LiFePO₄ lithium leisure batteries may have caught your eye at the show. They raise the bar for off-grid power in the UK. Its SMART5 range is built around Grade A+ matched cells, offering high energy density, compact design and full 100% usable capacity.
A 300A continuous Battery Management System (BMS) with active cell balancing, surge protection, low-temperature charging and Bluetooth/CANbus monitoring, keeps each pack safe and optimised.
Roamer’s modular, serviceable construction, with steel brackets, screw-fastened cases and replaceable internals, means you can repair or upgrade parts in the field.
These batteries are ‘drop-in’ upgrades: compatible with existing charger setups (Sargent and CBE, etc.) so, you don’t need a full rewiring.
The batteries are also backed by a 12-year warranty, full UK support, and certification (including ECE R-10) for caravan use. In short, Roamer delivers powerful, smart, repairable and safe lithium batteries, that let you take your home comforts off-grid without compromise.
Pioneer SXT-C10PS Retro Stereo
The Pioneer SXT-C10PS is the perfect blend of classic style and modern technology, designed for those who love a touch of retro charm in their caravan. This unit is ideal for replacing an old-fashioned stereo head unit, for one with all the latest bells and whistles. Behind its vintage cassette-style fascia hides a host of up-to-date features, including Bluetooth streaming, hands-free calling, USB and AUX inputs, plus DAB+ digital radio for crystal-clear reception.
The 1-DIN unit fits easily into most caravans, and offers excellent sound control through a multi-band equaliser, time alignment and high- and low-pass filters. There’s also adjustable RGB illumination to match your interior lighting. The SXT-C10PS brings stylish, high-quality audio to any touring set-up, seamlessly combining nostalgia with modern performance.
Truma CombiNeo 6 E 2-in-1 Heater
The latest Truma CombiNeo 6 E is a 2-in-1 central heating and hot water system engineered for caravans. It merges warm-air heating and continuous hot water delivery in one compact unit.
Hot water is available in just three minutes, and within eight minutes you can enjoy full showers. CombiNeo runs on gas, pure electric mode (up to 3kW), or in a hybrid mode, combining both, for outputs up to 7kW. The interior heating can deliver 1.8, 4.4 or 6kW in gas mode, and offers electric boosts when hooked up.
Intelligent combustion and efficient airflow-design ensure rapid heating of living areas.
The system is controlled via the Truma iNet X interface (panel or app), with modes like ‘Night’ or ‘Away’ for efficiency. It includes frost protection, automatic drainage and a smart design to save space and weight.
Isabella ISACOOL air-conditioning unit
The Isabella ISACOOL air conditioning system ticks all the boxes for caravan life. It’s designed for roof-mounted installation on vehicles, delivering both cooling and heat-pump heating, so you’re comfortable whether it’s a sweltering summer day or a chilly winter night.
ISACOOL handles ambient temperatures from -5°C right through to +50°C, giving you true all-season climate control. With a quiet compressor (59-64dB) and lightweight build (just 33kg externally), it’s well-suited to roof panels between 23 and 55mm thick. Control is via wireless remote or the HeroCamper AC smartphone app, letting you adjust modes, set timers and switch between °C and °F.
The ISACOOL breathes fresh air too, with a dedicated intake and it features an LED-lit control panel, making it a smart upgrade for touring comfort.
Price: £1499 at Isabella.net
Another useful upgrade you could consider is a caravan self-levelling system; it takes the strain out of achieving a level tourer once you’ve pitched up.
