The kitchen storage could be better, and only having Truma 2 heating means that this is unlikely to be an all-year-round tourer. The D4-4L looks the part, however, with its funky styling, and the design will also accommodate growing children.
Funky design
Flexible sleeping arrangements
- Storage space in the kitchen is a bit limited for four on tour
Mid-year is a tricky time to view an all-new caravan, when so many manufacturers are only weeks away from launching their next ranges. However, I’m taking a look at the Discovery D4-4L from Bailey, a company perhaps less tied in to the traditionally annual renewal programme.
This end-washroom four-berth has been part of the brand’s Discovery range since the second generation came along in 2023. So, how does it shape up, and should people looking for the best four-berth caravan be interested? I went to take a look.
One of the many effects of the pandemic was the demise of the Far Eastern factory producing the L-shaped awnings that Bailey had designed for the Discovery when it was launched at the start of the decade.
These awnings – the first and so far only inflatable L-shaped awning – were a game-changer in terms of the extra living space. If you can find a used caravan with one, I’d say go for it.
Still, if you’re planning on buying a new caravan, the Bailey Discovery D4-4L has a lot to recommend it on the outside. It looks stylish, with that large central window, the silver and blue colouring and the curved rear corners.
The bare A-frame provides a perfect place to attach a bike rack in a way that shouldn’t affect towing, especially as there is no front locker. I found the vertical grab handles made manoeuvring the van across soft gravel much easier.
Truma’s ATC system is a cost option (as is a caravan solar panel), but you still get an exterior locker door fitted as standard.
Lounge in the Bailey Discovery D4-4L
Although the central window is impressive, I thought the amount of daylight coming into the lounge would perhaps be no more than it would in most caravans. That’s because there are no windows either side of the big one.
Still, on the inside, this blank area is livened up with blue panelling, which neatly matches the smart blue sides on the settee base cushions and backrests. Daylight is also enhanced with two LEDs in the housing for the window, and a pair of corner spotlights with USB ports.
The main lounge can seat four, with two more in the side dinette. There are two mains sockets conveniently located here.
The backrest to the front seat in the side dinette can be removed to create an even longer settee on the offside.
The foldaway table can seat four, but it is stowed by the door, past the kitchen. There is no central chest, and the front sill is only average size. There are sockets and space for you to put the best caravan TV on the edge of the kitchen.
Kitchen in the Bailey Discovery D4-4L
Even if you have a TV, there is likely to be enough workspace in the kitchen. You get a dual-fuel hob – albeit only with three burners – and a round stainless-steel sink, all of which is well lit by a large window and two LEDs.
There’s only a combined oven and grill, but the half-height fridge is just about acceptable for four on a longer tour.
Washroom in the Bailey Discovery D4-4L
There’s no separate shower cubicle in the corner washroom, but the shower area is one of the biggest I’ve seen – although it only comes with one drain. There’s great headroom too, and a roof vent.
The basin, which I thought looks as if it folds but doesn’t, is in front of a mirror lit by an LED.
Beds in the Bailey Discovery D4-4L
The settees are too short to be made into single beds, although as mentioned, you can make the offside settee a bit longer by removing the seat backrest.
In any case, the double bed is easily made up with pull-out slats, and you don’t need to turn over the base cushions, either.
Turning the side dinette into two bunks is a bit more of a faff, because the bottom bunk requires an infill cushion.
But it is almost 6ft long, so you could sleep three adults and one smaller child in this van, or one older and one smaller child, something which should give you maximum flexibility.
For those of you who are looking to improve your current sleeping, don’t miss my tips on how to make a caravan bed more comfortable, either.
Storage in the Bailey Discovery D4-4L
The spare wheel takes up a good part of the offside underseat area, and the rest of it is quite cluttered. The nearside one is clear and has external access, although you do have to remove the backrest to get to it.
There are two corner shelves and two overhead lockers in the lounge, plus two more over the side dinette. None of these has push catches, so you’d have to make sure you don’t overload them. There is an almost full-height wardrobe by the door, with two shelves and another underneath.
There is also a large locker below the wardrobe, which you might want to use for kitchen storage.
Space in the kitchen is a bit limited, with an overhead locker (with a catch), a drawer and a locker under the oven – the rest is taken up with the gas bottle locker. There are two open shelves by the sockets. The washroom has a cupboard above the toilet.
The Xplore XC Lite has been restyled for the younger market, offering a great layout and plenty of storage for caravanners, as well as a smart new look. Another option to consider is the Swift Sprite Exclusive Alpine 4, a tourer with a large rear bedroom and a good spec, while managing to be a compact, yet comfortable four-berth.
Technical specification
- Price: £21,499
- Berths: 4
- MiRO: 949kg
- Payload: 133kg
- MTPLM: 1082kg
- Interior length: 4.17m
- Shipping length: 5.92m
- Overall width: 2.23m
- Contact baileyofbristol.co.uk, leedscaravancentre.co.uk
Spec list
- Al-Ko galvanised chassis with AKS 3004 stabiliser
- Spare wheel
- Polyplastic double-glazed windows
- Alloy wheels
- Truma Combi 2 heating
- LED lighting throughout
- Status 570 telescopic directional aerial
- Pre-wired for optional Avtex Wi-Fi system
- 92-litre Dometic fridge
- Thetford Triplex combined oven and grill with dual-fuel hob
- Ecocamel shower head
- Thetford 12V electric flush toilet
- Four mains sockets and two USB ports
- Front double bed: 1.90 x 1.34m Or two singles: 1.34 x 0.61m (offside single extends to 1.91m)
- Bunks: 1.81 x 0.71m (top); 1.73 x 0.61m (bottom)
If you are a newcomer to the van lifestyle and are looking for tips on taking your tourer out for the first time, don’t miss our guide to towing a caravan for beginners.
| MiRO | 949 kg |
| Payload | 133 kg |
| MTPLM | 1082 kg |
| Interior Length | 4.17 m |
| Shipping Length | 5.92 m |
| Width | 2.23 m |
