Caravanning is a basically simple endeavour. Yes, it will involve a little elbow grease when setting up, but nothing is too mentally taxing. However, one thing that did catch me out once was the towing electrics of my caravan.
Back then, I was still a bit of a newcomer to caravanning, and the issue involved the tourer’s 13-pin connector.
Every other time I had been touring, the van’s connector slotted straight into the tow car’s receiver – a quick twist, then the ATC light would flash on and I’d hear a whirr as the system prepped itself.
However, on this occasion, the socket’s internal plastic lug wouldn’t line up with its slot when the external ‘push and twist’ thread was aligned. There was simply no way of connecting up the two. I was, quite frankly, baffled.
Brute force wouldn’t work – I even considered chiselling the lug off with a penknife – but after a stressful, vocally colourful 20-minute battle, I finally gave in and called the manufacturer who had loaned us the tourer for a feature that I was writing.
Unable to help out remotely, they said to leave the van on site and they would collect it. Now that’s great if you’re a journalist, but it would not have been much use for any other caravanner.
A common problem with the caravan connector
Back home, I researched the issue online and discovered this misalignment is actually a fairly common caravanning problem.
Many caravanners will get to experience it at least once or twice over the years, but some have to deal with it on almost every trip.
The solution is simple and very cheap – you just need to purchase an alignment tool from your local dealership or online. They cost around £5, and I’d recommend keeping one of these caravan essentials permanently in your van or tow car at all times, just in case.
A 13-pin alignment tool
Everyone should have a 13-pin alignment tool!
This cheap plastic ‘holiday saviour’ slots onto the male caravan connector, allowing you to turn the alignment lug independently of the external casing with its screw-thread.
One or two tweaks and you’ll have the lug and screw-thread channel in perfect alignment (in other words, diametrically opposed). Crisis over!
Do note that this problem only affects 13-pin connectors. I believe every dealer should tell their customers about this potential issue in the handover, and give them a free alignment tool. Now, what great customer service that would be.
Electric caravan towing cables
The common-or-garden caravan electric towing cable supports a vital link between your tow car and your caravan.
It provides the power for key lighting and systems, ensuring you’re visible, legal and safe on the road, and can relax on site with the best caravan leisure battery fully charged and a chilled Pinot or pint.
A flange towbar with twin electric sockets and protective plate
Flange towbar with twin electric sockets and protective plate to prevent damage to the bumper
The towing cable connects the electrical systems of your car to those on your caravan.
This includes the rear lights, indicators and brake lights and, depending on the type of plug, additional features such as the fridge power and battery charging.
Connecting the electric towing cable
Connecting the electric towing cable is usually a hands-and-knees job!
The cable is permanently attached to the caravan and connects to the car through a plastic ‘block’ which contains metal connections.
Your tow car has the female receiver, while the electric cable on the caravan contains the male pins.
Car-side electrics
Car-side electrics are coded to the vehicle
Most of the pins supply power to a specific part of the tourer, for example, the brake lights or fridge, but some are earths, and there’s usually a spare link, too.
The different types of towing socket
The towing socket is the unsung hero of your electrical set-up – it’s where your tow car and your caravan connect to share power. There are three main types of towing connectors: the single 7-pin connector, the two 7-pin plugs, and a 13-pin connector – here, I’ll run through them.
The functions of pins
Diagrams from Westfalia
Single 7-pin connector (12N)
These are an older, more basic design for trailers. The N stands for ‘Normal’. They just power the lights, and are not a suitable choice for modern caravans and tow cars.
Two 7-pin plugs (12N + 12S)
This system is designed to add certain caravan functions to the 12N set-up. It was used on older caravans and involves two separate plugs – 12N for the lights, and 12S for the fridge and the battery.
The S in the name stands for ‘Supplementary’. These can still work very well, but they are rather more prone to corrosion and decoupling.
13-pin connector
Back in 2008, the much neater and simpler 13-pin plug was introduced to the market.
This will handle all of the necessary power connections (lights, battery charging and fridge) through a single, twist-to-lock connection.
A swivelling 13-pin socket
Swivelling 13-pin socket
If you have mismatched connectors – an older tow car with a new caravan, or vice versa – don’t panic.
Simple adaptors are widely available for about a tenner and will easily bridge the gap between old and new systems with a quick twist.
Bypass or vehicle-specific towing electrics
Modern caravan electrics sort the pros from the pretenders.
If you’ve bought the cheapest towbar kit going, chances are it includes a basic bypass wiring system. These set-ups don’t exactly integrate with your car’s electronics – they simply work around them.
A bypass system will get your lights blinking and your fridge humming, but that’s about it.
Crucially, the car won’t even realise it’s towing. That means key systems like traction control, ABS and adjustable suspension don’t know to recalibrate.
On a towing course
On towing courses, you’re taught to put a twist in the cable to tension it and keep it off the ground
Even your rear parking sensors might start having a meltdown, when they think a caravan’s tailgating you at three feet!
Now contrast that with a vehicle-specific wiring loom. This plugs directly into the car’s brain – known as the CAN bus – allowing it to ‘chat intelligently’ with the caravan.
Removable swan-neck towbar with swivelling socket fitted
The result? Everything works in harmony, from adaptive suspension to trailer stability programmes. In effect, it’s the towing equivalent of driver and co-driver in perfect unison.
OE factory-fit towbars are fully integrated – but they often cost well over a grand and can hold up a new car delivery. However, top-tier brands (such as Tow Trust, Witter and Westfalia) now offer tailored kits for many models, usually for around half the OEM price. Fitting takes three or four hours.
How to connect your electric towing cable
1 Ensure the car and caravan are parked on level ground with the brakes on and the ignition off.
2 Put a twist in the cable to tension it and keep it off the ground (but not too tight, as a sharp turn could pull on it and cause damage).
3 Align and insert the plug (twisting to lock if it’s a 13-pin).
4 The spring-loaded cover should close on the connector, preventing it from turning.
5 Always check all lights are working before setting off. Ask a second person to help, or use a reflection in a window or garage door.
Maintenance tips for your towing connectors
  • Keep both the plug and the socket clean and dry.
  • Use electrical contact spray or WD-40 to repel moisture. Do this whenever you’re storing your caravan, and after each trip.
  • For 13-pin plugs, use a protective cap when not in use. The alignment tool also serves this purpose.
  • Regularly check the cable for signs of wear, crushed sections or exposed wires. If a cable has dragged on the floor during towing, it makes sense to have it replaced, unless the damage is only very superficial.
  • If you spot corrosion on any of the pins, treat this as a matter of urgency.
  • If your leisure battery isn’t charging or your caravan fridge isn’t cooling when you’re towing, check the towing cable connections, as poor unions can cause these issues.
Legal and safety points
  • It’s a legal requirement for van lights to work correctly. Non-functioning indicators or brake lights can lead to fines, or worse, accidents.
  • If you’re towing a newer caravan with an older car (for example, with 12N/12S), you might need an adaptor to convert to the 13-pin system – and vice versa.
  • Always disconnect the electrics before unhitching, to avoid straining the cable or damaging the socket.
Caravan stabilisers are another important towing aid you will want to know about too – they are an important accessory that helps to improve the stability and safety of your tourer.
