Knowing what PSI (pounds per square inch) your caravan tyres should be is a crucial step to ensuring you stay safe when you’re on the road.
These bits of rubber will play a significant role in ensuring you safely reach your destination, and knowing the correct pressure is going to be an important part of your caravan tyre care routine.
Caravan tyres generally have higher pressure requirements than car tyres. That’s because they are often commercial-spec, similar to a van, with stronger sidewalls.
Just in case you weren’t aware, in the UK, tyre pressure is measured in PSI (pounds per square inch) or Bar (1 Bar = 14.5psi). Most car tyres are inflated to between 30 and 40PSI, but caravan tyres often require 45 to 60PSI.
However, it would be difficult, and dangerous, for me to quote you a tyre pressure without more details. It’s crucial to check the figures for your specific caravan’s model and year, due to potential changes across seasons.
If you have a caravan from the past five years, you could start by checking the weight plate of your caravan, where it should be listed. However, we’d recommend checking it with the figure listed in your caravan’s handbook or, if you don’t have that, check the website of your caravan manufacturer or give them a call.
Alternatively, contact your local AWS caravan technician, or check out the excellent website, www.tyresafe.org, and search caravan tyre pressures.
It’s crucial that you know the correct pressures for your tourer’s tyres. Under-inflating your tyres will create wear on both edges of the tread, while over inflating them usually causes premature wear in the centre of the tread. Both faults will damage your tyres and could cause tyre failure and sudden deflation.
Cost-effective tyre-pressure-monitoring devices like TyrePal, beam the pressure from each tyre to a display on your dashboard in real-time. You can get an idea of what this involves in Nigel Hutson’s guide to how to install the TyrePal TC215.
The benefit of such a device is the reassurance it gives you in knowing that your tyres are performing as expected when you are towing a caravan. As towing gadgets go, it can definitely be worth considering.
