Rot in the floor of our 1998 budget Bailey was a timely reminder that caravans often start to deteriorate on the quiet, and the best ways to avoid that are to proactively go searching for potential problems. During a bit of routine prodding and poking, I found a little area that looked prime for a perk-up on the back wall of the caravan.
It was in the mid-2000s that the trend for single-piece caravan sidewalls became popular. Prior to that, it was popular for caravans to be assembled from smaller pieces of aluminium that were bonded together with a strip covering the joins screwed over the top. It works well enough, but extra screw holes and joins mean more places for water to find its way under the skin.
We had no evidence that water was breaching Penny’s perimeters (see: our guide to caravan water ingress), but there was significant evidence that things were starting to break down on the back wall. The old trim was rock hard, there was evidence of deterioration and the end caps were starting to sprout moss. A good place to start!
You can also see how I went about dealing with the soft floor in the rear corners of my caravan, and also take a look at what I did to smarten up the A-frame fairing on Penny too.
One bit at a time
The problem with repairs such as this is that they can be like pulling at a thread. Remove one bit of trim – another shows up as a problem, and before you know it, you have a caravan in bits on your driveway. We were determined to stick to small areas, fixing things as we went.
Nigel replacing the trim
Nigel gets to work replacing the trim
If this is your first foray into caravan damp prevention and repair, there are a few golden rules that will help lift your mood. First up, you’re going to want to choose the right weather conditions, just as you would if you were cleaning a caravan. To replace the Herzim trim, I’d advise picking a nice day to do the work. There’s nothing worse than stripping your caravan’s weatherstrips only to find there is a monsoon on the way.
The other thing to bear in mind is that 90% of the job is cleaning. Anything that you plan to reseal needs to be spotless before you start sticking things back, or you are asking for trouble. New sealant typically doesn’t like sticking to old sealant, and the result can be a leaky caravan from the very place you thought you had just protected.
See what I’d previously done to prevent any water running down the rear of my caravan from getting to the floor, too. For more DIY, you can also see how I fitted retaining straps to my caravan’s locker.
What is Herzim trim?
The oddly named plastic insert that fits in your caravan extrusions to cover the screwheads is named after the Herzim Manufacturing Company of Detroit, which invented it.
The flexible vinyl insert is the industry standard for hiding unsightly screws and waterproofing the aluminium rails on boats and vans.
It is now a generic trademark like Hoover and used for all inset trims of the type.
The Herzim trim on Penny
The PVC trim that covers the fixings in caravan rails is called Herzim trim
A quick Google for Herzim trim brings up loads of suppliers, but the helpful YouTube tutorial videos put up by Seals Direct meant that I settled on them as the supplier of choice.
The video tutorials showed the presenter using a Herzim trim tool. Having installed this trim in the past with a pair of electrical screwdrivers and several hours of my time, I was well up for a labour-saving device; so I took the plunge with a few metres of what I hoped was the correct trim and a £10 tool, which would be a handy addition to my caravan toolbox.
Removing one of the plastic end caps
Plastic end caps were removed for access
Following advice on its website, I removed a small section of trim from the caravan to measure it. I also measured the channel in the rail that I removed it from.
There are many different sizes available, but given that the trim seemed to measure around 11mm and the rail at around 8mm, I settled on a 12mm trim.
Using a ruler to show the Herzim trim is 12mm
Herzim trim comes in many different sizes. We opted for 12mm to fill the 8mm channel
I went for a slightly creamy white to match the van’s colour, but there are dozens of colours to choose from.
Putting it back together
A couple of days later, a nicely packaged box arrived from Seals Direct and I set about the task. It is quite straightforward to do, but I started with the straight rail above the rear window as it looks in a bit of a state and the end caps also looked the worse for wear. I could remove and reseal these as part of the job.
Removing the old trim with a Herzim tool
The Herzim tool is used to pull out the old trim
The Herzim trim tool has a spiteful little hook on one end for digging out the old trim, and a roller on the other for reseating the new.
Cleaning the area for sealing
It’s vital to clean the area for effective sealing
I wouldn’t say it made the job a pleasure, because it’s quite fiddly and boring, but it does make it a lot less frustrating than my previous efforts without the tool to hand.
Pushing the trim into the channel with the roller end
Use the roller end of the tool to push the trim into the channel
Replacing the Herzim trim took around an hour, thanks to the cleaning up, removing a crusty looking old screw in the rail and generally ensuring things were in good shape.
Trimming the end of the Herzim trim with a knife
Run the trim off the end of the rail and trim it flush with a knife
I was expecting to be wowed with my handiwork, but honestly? I’m not terribly thrilled with how it looks.
One of the new stainless steel screws
New stainless screws replace rusty originals
It’s definitely smarter than the old trim that was there before, and will now protect the van better. But this new trim shows bumps where each screwhead is installed along the rail.
The completed Herzim trim
It’s an improvement without doubt, but you can still see bumps where the trim goes over the screwheads. I think we can do better!
It is keeping the weather off the screws, the end caps are newly sealed and the Herzim trim tool worked like a charm. But I’ll be scouring the internet for ways to get a smoother finish before I start resealing the awning rails.
Something else you may want for your tool kit is a socket set – if this applies to you, we can help, as we share our picks for the best socket set.
