Caravan toilets: the main types and the recent innovations
You can’t beat the good old caravan cassette loo. Or can you? Peter Rosenthal explores some innovative alternatives that promise a new experience.
Diamond Dave explains what you can do to fix - and prevent - black bits from appearing in your caravan cassette toilet when you...
Nigel Donnelly takes a look at Penny's A-frame fairing, as he seeks to give his 1998 project caravan a smarter look.
We've picked out the best cleaners for a caravan to help you rid your tourer of grime, black streaks and algae.
A rear-lounge glow-up starts with fixing some bothersome blinds. Nigel Donnelly explains how to repair Seitz caravan blinds.
Nigel Donnelly now turns his attention to fitting LEDs with USB charging sockets into the rear lounge of his 1998 caravan.
Nigel Donnelly talks you through the process of how to install caravan solar panels, so you can take advantage of the free power from...
Nigel Donnelly explains the step-by-step process he followed to fix the leaking toilet cassette in his 1998 Bailey caravan.
Are you wondering how to empty a caravan toilet? Follow a few simple steps and you'll be emptying the cassette like a pro.
Many caravans have Alde heating, but have you ever wondered how its products are put together? Nigel Hutson heads to Sweden to find out.
John Sootheran explains how taking your caravan off-grid can allow you to enjoy a whole new touring experience.
Nigel Donnelly turns his attention to the caravan plumbing in his 1998 Bailey caravan
Nigel now turns his attention to Penny's plumbing and the A-frame, as he continues to improve his 1998 Bailey caravan.
Knowing what you can safely fix yourself means you don’t always have to schlep to a dealer and is the key to trouble-free touring
A minor 12V project shone a light on some substandard low-voltage wiring, so Nigel Donnelly sets about keeping the power on next season
Nigel Donnelly sets about more repairs, explaining the process of reinstating the towing electrics and the all-important gas check.
Keep your van water supply flowing with a functioning filter, says Tony Brown
Prolong your heating system’s life with some basic maintenance, says Nigel Hutson
If the bright white background on your Alde control panel is keeping you awake at night, there’s a simple solution, says Nigel Hutson
If you’re going to install a jack, make it the right one for the task, says Nigel Hutson
The submersible pump is essential to your caravan water supply, but if it fails, Sam Coles can show you how to replace it
Sammy Faircloth has some practical tips about keeping your acrylic windows scratch-free
Overwhelmed by the number of caravan accessories you're running? This simple power hub could be the answer, says Nigel Hutson
Fit this simple battery back-up unit and you can forget about resetting the clock on the Alde's control panel, says Nigel Hutson
Your caravan's water supply is essential, so you need to know how to find and fix basic problems. Nigel Hutson guides you through
These two essentials prompt many queries from new caravaners. Nigel Hutson explains all about power for your fridge and water supplies for your flush
What should you expect from a full caravan service? John Sootheran finds out
In addition to your caravan's annual service, there are plenty of tasks to tackle yourself and keep your tourer in tip-top condition throughout the...
If you watch television on tour in your caravan, you need to know how to get a perfect picture, wherever you pitch. Here's the...
The leisure battery is a caravanner's best friend, and of course, you should choose your friends wisely and treat them well. Our guide gives...
It's easy to install this neat charging pad, says Nigel Hutson, and then you can say goodbye to all those dangling cables and wires
Caravan water systems bring domestic ease to our lives on site. John Southern explains how they work and how to maintain them
Preparing your van for storage involves a few key tasks, says Sammy Faircloth
Need extra electricity to run a pump or emergency lighting? Construct this simple unit, says Sam Coles, and you'll have 12V wherever you go
Gas is a brilliant fuel for caravanners, and here, John Sootheran outlines its many pros... and a few cons
Old caravans never die - they just get recycled! John Sootheran discovers a thriving industry that's great for the planet, and your wallet
Tony Brown explains how a simple DIY job can upgrade your storage
Good lighting makes all the difference to an interior, but which type is best for your van? Sammy Faircloth looks at options for upgrading
Anna Lyon and family love everything about their Eriba - except for the furnishing fabrics, which they didn't choose. Time for a change!
Curtains and blinds are decorative and stylish, but also essential for privacy and insulation, so good maintenance is important, says Sammy Faircloth.
Installing a fridge fan can boost your fridge’s cooling power, which is especially useful in hot weather. Nigel Hutson shows you how.
Getting in and out of your caravan is much easier with a grab handle, says Tony Brown.
