How to repair Seitz blinds in a caravan
A rear-lounge glow-up starts with fixing some bothersome blinds. Nigel Donnelly explains how to repair Seitz caravan blinds.
Nigel Donnelly now turns his attention to fitting LEDs with USB charging sockets into the rear lounge of his 1998 caravan.
Nigel Donnelly talks you through the process of how to install caravan solar panels, so you can take advantage of the free power from...
Many caravans have Alde heating, but have you ever wondered how its products are put together? Nigel Hutson heads to Sweden to find out.
If the bright white background on your Alde control panel is keeping you awake at night, there’s a simple solution, says Nigel Hutson
If you’re going to install a jack, make it the right one for the task, says Nigel Hutson
Sammy Faircloth has some practical tips about keeping your acrylic windows scratch-free
Fit this simple battery back-up unit and you can forget about resetting the clock on the Alde's control panel, says Nigel Hutson
What should you expect from a full caravan service? John Sootheran finds out
In addition to your caravan's annual service, there are plenty of tasks to tackle yourself and keep your tourer in tip-top condition throughout the...
If you watch television on tour in your caravan, you need to know how to get a perfect picture, wherever you pitch. Here's the...
Tony Brown explains how a simple DIY job can upgrade your storage
Getting in and out of your caravan is much easier with a grab handle, says Tony Brown.
Bluetooth has made auxiliary jack sockets less of an essential but they offer an additional option for audio and are very simple to fit,...
Hitching and unhitching can cause the odd scratch to your car, but this simple DIY project will protect your bumper, says Tony Brown.
If you are tired of poor-quality door and locker catchers that wear out all too quickly, it's simple to make your own, says Sam...
Tony Brown offers essential advice on breakaway cables and why they're essential, in our series of everyday fixes for your caravan.
Brighten up the caravan kitchen with new LED lighting. LED strips are simple to fit and make meal preparation much easier, says Nigel Hutson.
In our series of everyday DIY fixes for your caravan, Tony Brown finds a solution for storing free-standing tables.
This simple project allows you to watch TV in comfort in cold weather, says Nigel Hutson
Never underestimate the importance of fire safety in your caravan; here are some tips from Tony Brown to help you stay safe in your...
We talk you through all you need to know to choose the an aerial, and also share a few tips on improving the reception
Enjoy off-grid touring for longer on your caravan holidays! Nigel Hutson explains how to install a solar panel to your van – it's easier...
Practical Caravan's Bryony Symes has a dozen resolutions you can take on to assure yourself safer touring in 2014
How to get the best from your Truma Trumatic S3002 heater
If you are installing air-conditioning to your caravan, make sure you select a suitable unit and fit it properly – here is reader Tony...
ONCE YOU'VE WORKED out which air-conditioning unit you're going to use and where to site it (click here for reader Tony Brown's advice on...
WAKING UP ON a cold morning, many caravanners must, like me, jump out of bed, turn on the heating then jump back in while...
HERE ARE THE 18 steps involved in fitting an Al-Ko Mammut caravan mover, plus Doug's verdict on the product and the installation process. STEP...
SOME MONTHS AGO I had the chance to try out Al-Ko Kober’s new caravan mover, the Mammut, and was very impressed with it –...
IS YOUR REGULATOR definitely blocked or have you run out of gas? Ensure your cylinder is not empty.Are you using butane and has the...
CARAVANNERS HAVE reported the failure of their LPG regulators since the industry changed from fitting regulators directly to gas cylinders to fitting them to...
I can’t say that I’ve ever been an enthusiast of hitch/stabilisers although I have towed with them on many occasions over the years and...
